Page 1 of 3 1 2 3 >
#307375 - 09/05/11 08:42 AM "minimum" problem
geronimo Offline
Loc: Croatia / Rijeka
Hi guys. Lately I have problems with the “minimum”. The car rpm-s go to low and sometimes the engine turns-off . This especially happens when the engine is cold.
Now I know of the problems with starting the engine and rpm-s going low on all the fiesta range but I thought it was fixed with the last software.
They told me they uploaded the latest one, how can I check this?
I also have the problem, going down the hill for example, pushing the clutch down and the rpm pointer goes crazy up and down .
Regards.
Fiesta ST (Frozen White, no stripes)
http://www.fordfiestast.co.uk/showflat.p...&PHPSESSID=
#307376 - 09/05/11 08:44 AM Re: "minimum" problem [Re: geronimo]
clean the throttle body
#307377 - 09/05/11 08:44 AM Re: "minimum" problem [Re: geronimo]
Have you cleaned out your throttle body
#307378 - 09/05/11 08:45 AM Re: "minimum" problem [Re: ROB IS THE STIG]
haha Kenny
#307379 - 09/05/11 08:45 AM Re: "minimum" problem [Re: ROB IS THE STIG]
lol great minds think a like mate
#307380 - 09/05/11 08:48 AM Re: "minimum" problem [Re: ROB IS THE STIG]
geronimo Offline
never. Is it hard to do it? Is the MAF sensor somewhere in that area also, cos I know of the problems when it get's dirty. I'll take a look in ETIS about this.
If you have some other ideas let me know.
cheers.
#307381 - 09/05/11 08:53 AM Re: "minimum" problem [Re: geronimo]
A few people on here have had idle issues that instantly improve with a clean TB, very easy to sort out, u may be suprised at how filthy it gets.........
#307382 - 09/05/11 10:59 AM Re: "minimum" problem [Re: kenny]
+1 I did that when I was charged and it stopped me from cutting out too!
It's always the throttle body that needs cleaning!
#307383 - 09/05/11 11:25 AM Re: "minimum" problem [Re: Kaxe]
geronimo Offline
thanks guys.
my next question is, how do you clean the TB ?
is it just with compressed air or I need some special cleaner/liquid?
cheers.
#307384 - 09/05/11 11:28 AM Re: "minimum" problem [Re: geronimo]
carb cleaner do not use wd40
#307385 - 09/05/11 11:36 AM Re: "minimum" problem [Re: kenny]
geronimo Offline
thank you.
#307386 - 09/05/11 12:25 PM Re: "minimum" problem [Re: geronimo]
clean your air filter too
#307387 - 09/05/11 12:44 PM Re: "minimum" problem [Re: YellowBadge]
geronimo Offline
It'a a K&N panel and I installed it around 28 000km (now I have 30 000km) so I definitely think this is not the case ?
#307388 - 09/05/11 12:48 PM Re: "minimum" problem [Re: geronimo]
STASON Offline
get some duck tape and tape you accelerator to the floor at a certain level enough so you don't have to hold your foot down when idle incase you loose
#307389 - 09/05/11 12:52 PM Re: "minimum" problem [Re: STASON]
geronimo Offline
#307390 - 09/05/11 04:38 PM Re: "minimum" problem [Re: geronimo]
Don't play with the butterflys though, believe Dan played with his and messed them up
#307391 - 10/05/11 08:46 AM Re: "minimum" problem [Re: Adam08]
thewhite1 Offline
When I had my head and all skimmed, I had the same prob with idle and it was all over the place and stallin on me every time I stopped the car!!!! The air filter was very dirty so cleaned it, and seen the gunk in the throttle body.
Its 4 bolts that take 2 ticks to take off. Use carb cleaner and kitchen roll to clean it. Was so clean when I was done and she run like new car. Idle was perfect. Was crazy the difference!!
DO IT!!!!!!!!!!
#307392 - 10/05/11 08:53 AM Re: "minimum" problem [Re: thewhite1]
Definatly a top tip this one Eratic idle - 9/10 is a filthy TB So always check that 1st
#307393 - 10/05/11 01:32 PM Re: "minimum" problem [Re: thewhite1]
geronimo Offline
DO IT!!!!!!!!!!
sir, yes sir :-).
I'll do it.
thanks guys.
#307394 - 10/05/11 03:09 PM Re: "minimum" problem [Re: geronimo]
Lets us know how u get on buddy
#307395 - 13/05/11 09:36 AM Re: "minimum" problem [Re: ROB IS THE STIG]
geronimo Offline
ok, just about to head to the shop to get some carb cleaner, I find on the net some tips not to use the normal carb cleaner but a specific throttle body cleaner.
Also I found on youtube a guy cleaned with carb cleaner and then also with a bit of brake clener?
One guy mentioned that some Ford cars specificaly shouldn't be cleaned with carb/throttle body cleaners because of some special coating they have on the TB.
So i want to be sure not to mess something up. I think I can get the carb cleaner spray. for throttle body spray I'm not sure.
cheers.
#307396 - 13/05/11 02:54 PM Re: "minimum" problem [Re: geronimo]
thewhite1 Offline
Trust me, ur readin to much into it. Jus any carb cleaner spray. Worked a treat on mines. 15 min job
#307397 - 13/05/11 02:58 PM Re: "minimum" problem [Re: thewhite1]
Yeh i agree, anything but WD40
#307398 - 13/05/11 03:44 PM Re: "minimum" problem [Re: ROB IS THE STIG]
geronimo Offline
ok, just wanted a confirmation. I bought ABRO carb and choke cleaner. tomorrow I'm doing it
#307399 - 13/05/11 03:50 PM Re: "minimum" problem [Re: geronimo]
Let us know how it goes, should sort out your problem
#307400 - 14/05/11 07:03 AM Re: "minimum" problem [Re: ROB IS THE STIG]
Just ask Dan the man
#307401 - 14/05/11 08:57 AM Re: "minimum" problem [Re: Alex_H]
Yeh
#307402 - 21/05/11 02:41 PM Re: "minimum" problem [Re: ROB IS THE STIG]
geronimo Offline
TB cleaned . It was very dirty. I'll put some photos later on
#307403 - 21/05/11 04:06 PM Re: "minimum" problem [Re: geronimo]
Have u noticed a change at all??
#307404 - 21/05/11 04:16 PM Re: "minimum" problem [Re: ROB IS THE STIG]
geronimo Offline
well it behaves different but I didn't take it for a ride yet. I'm going in the next hour. I'll update later on if it solved the problem.
in the parking when I switch on, I push the accelerator, it revs, and then it doesn't go all the way down immediately but in 2 stages, first to around 1100, and than lower to default idle. This could maybe even be because of the reset? (I removed the battery while I was doing all the work as stated in ETIS procedures when cleaning TB, and then when everything was ready, turned the key in position 2 for 1 minute so the TB "makes" all the data.
cheers.
#307405 - 21/05/11 04:17 PM Re: "minimum" problem [Re: geronimo]
#307406 - 21/05/11 06:01 PM Re: "minimum" problem [Re: geronimo]
Mine does this, it idles at 1100 until warm so I wouldn't worry too much
#307407 - 31/05/11 02:50 PM Re: "minimum" problem [Re: Duncan_P]
geronimo Offline
hi guys. here are the photos of TB.
dirty:
cleaned:
and this is the "part" after TB inside. It's very dirty. I cleaned it with the rag as deep as I could have reached.
The car definitely works better now, and this was really an easy fix.
cheers
#307408 - 02/06/11 08:39 AM Re: "minimum" problem [Re: geronimo]
think i'll do this to mine at the weekend, noticed its a bit eratic at the traffic lights
Page 1 of 3 1 2 3 >
0 registered (), 1131 Guests and 0 Spiders online.
